Custom Box Furnace Designed for Strict Operational Constraints
A specialized U.S. government manufacturing facility will install a custom thermal processing system to support expanded high-temperature operations. The new box furnace will enable the facility to scale a previously validated thermal process, increasing capacity while meeting strict spatial and operational constraints within the plant environment. The system is designed to support demanding thermal applications required in government manufacturing.
Image Credit: Gasbarre Thermal Processing Systems
The project involves installing a custom-engineered box furnace and loading system designed to meet the facility’s layout and process requirements. The direct-fired furnace will operate in an air atmosphere with a maximum temperature of 2100°F and represents the largest configuration that can be accommodated within the available footprint. The system supports a specialized high-temperature thermal operation that had previously been proven at a smaller scale and is now being expanded to meet increased production demands.
Patrick Weymer
Business Development Manager
The thermal processing system is being supplied by Gasbarre Thermal Processing Systems, which worked with the client to engineer a design that meets strict space, access, and installation limitations that had previously restricted equipment options. Rather than modifying a standard design, the furnace was developed specifically for the application to ensure compatibility with the facility’s constraints and processing requirements.
The project progressed under a tight timeline, with Gasbarre working closely with the client from the initial inquiry through final authorization. According to Patrick Weymer, business development manager for Gasbarre, “some applications don’t allow for compromise, whether due to space, schedule, or process requirements.” He added that certain applications require custom-engineered solutions when standard equipment won’t work.
Custom Box Furnace Designed for Strict Operational Constraints Read More »
