Heat Treater Expands with Vacuum Furnace
HTD Size-PR LogoA Swiss commercial heat treater ordered a vacuum furnace. A system will increase the production capacity of their nickel and silver brazing processes.
Maciej Korecki
SECO/WARWICK
The SECO/WARWICK vacuum furnace helps with hardening larger size parts and significantly increases the efficiency of the current hardening plant. The furnace increases production. In the version ordered by the Swiss, a large working zone (36"X36"X48") with the potential to adjust to an oversized load utilizes the advantages of a round heating chamber.
“[With a] cooling capacity of 15 bar, it is possible to process parts that require very fast cooling . . . . Vector also allows the system to perform more difficult brazing processes with either nickel or silver," explains Maciej Korecki, vice president of the Vacuum Furnace Segment, at SECO/WARWICK Group. "This is our second installation with this partner. Previously, we delivered a solution from the SECO/WARWICK furnace family of a similar size, in a non-pressurized version."
Heat Treater Expands with Vacuum Furnace Read More »
