Ellwood Group
Steel Components Supplier Branches Into Aluminum with New Facility
Source: Light Metal Age
An Ohio-based supplier of engineered steel components for multiple applications has recently begun construction on a facility that will manufacture a material other than steel: aluminum.
Ellwood Group Inc, which manufactures steel for the energy, aerospace, automotive and general manufacturing industries is building a new aluminum casting facility at its Ellwood Engineered Castings site in Hubbard, Ohio.
Read more: “Ellwood Group Expanding into Aluminum Casting”
Steel Components Supplier Branches Into Aluminum with New Facility Read More »
Ellwood Group Acquires Gulfco Forge Company
  Source:  ForgingMagazine.com
Gulf Coast Machine and Supply Company (Gulfco) utilizes forging equipment including a 3,500-ton open-die press, a 2,000-ton press, 10,000-lb. hammer, and several ring mills.  It also has heat-treating, finish machining, and product testing capabilities. The Ellwood Group has purchased Gulfco and will operate it under EGI.
Read more: Ellwood Group Acquires Gulfco Forge by Robert Brooks
Ellwood Group Acquires Gulfco Forge Company Read More »
