Firearms Manufacturer To Receive Furnace To Heat Treat Aluminum
A leading firearms manufacturer ordered a continuous conveyor furnace from a Wisconsin furnace supplier. The oven will be used for heat treating aluminum parts prior to quenching.
Source: Wisconsin Oven Corp.
Vice President of Sales
Wisconsin Oven
This industrial conveyor furnace has a maximum temperature rating of 1,110°F and interior chamber dimensions of 4’2” W x 30’ L x 1’ H. The parts are manually loaded onto the flat wire belt conveyor and transported through both zones of the oven. The recirculation system utilizes two 56,000 CFM blowers, and the furnace is equipped with a performance monitoring system that collects information from predictive maintenance sensors.
“[W]e provide custom design solutions to meet each of our customer’s unique requirements," commented Mike Grande, vice president of sales at Wisconsin Oven Corporation. "This conveyor furnace was designed to sit at an incline which allows for the quench tank to fit under the conveyor discharge end.”
Firearms Manufacturer To Receive Furnace To Heat Treat Aluminum Read More »
