Alloy Heat Treatment
Heat Treater Performs Brinell Hardness Testing with Precision for Primes
The largest subcontract heat treater of aluminum alloys in the UK, accredited to process components to Prime specifications, turned to a manufacturer of Brinell hardness testing machines to develop a more efficient testing process.
Foundrax BRINtronic automatic Brinell microscope
Alloy Heat Treatment (AHT), which serves the aerospace, automotive, energy, and other sectors, has a large number of prime customer approvals including Leonardo Helicopters, Airbus, Safran, Boeing, and BAE Systems. They are accredited to heat treat to these Prime’s specifications and often work as a trusted supplier to other companies that deal directly with them. Part of the Prime specifications dictates that Brinell hardness testing is carried out prior to releasing the components. AHT settled on the Foundrax BRINtronic automatic Brinell microscope, designed by Foundrax Engineering Products, based in Wessex, England.
“Part of the release process for aluminum alloys is that we must do conductivity and hardness testing on every job that leaves us,” said Steve Roberts, Quality Director with Alloy Heat Treatment. “As such we were looking at ways that we could gain efficiencies in this process. Using the BRINtronic from Foundrax has allowed us to gain these efficiencies.”
Brinell hardness measurements were required to be taken in areas of components where access is limited by intricate machine webbing or where the nose diameter of the microscope is restricted to approximately 30mm.
Alex Austin, Managing Director, Foundrax
“One of the problems we needed to solve with equipment selection is that the microscope must get into quite intricate places,” continued Roberts. “All the other microscopes we looked at have wide noses on them so, the design of the Foundrax scope was right up our street. We’ve used the manual Foundrax microscopes for as long as I’ve been here.”
“As the microscope automatically measures the indentation at multiple points, results are instant,” said Alex Austin, Managing Director of Foundrax. “They are recorded, and of course, the operator doesn’t have to turn the microscope 90 degrees and remeasure as he would with manual measurement. There is well over a 50% saving on measuring time.”
Foundrax BRINtronic display
“Obviously, the usability of the BRINtronic suited us,” said Roberts, “because we could get it into the places that we would struggle with using the competitor’s equipment. The process of measuring was far easier with the Foundrax BRINtronic as with the others we had to try and hold it with both hands and press buttons. They weren’t particularly well balanced either so in practice we were losing efficiencies rather than gaining them.”
Main photo caption: Steve Roberts of AHT uses the BRINtronic testing machine from Foundrax.
Heat Treater Performs Brinell Hardness Testing with Precision for Primes Read More »
Quick Heat Treat News Chatter Items To Keep You Current
The heat treat industry is one of people transitioning and companies executing business, achieving goals, and receiving acknowledgments. Heat Treat Today begins a feature highlighting representative moves, transactions, and kudos from around the industry.
Gabriel Giraldo, Sales Engineer, Solar Atmospheres of South Carolina
Personnel Changes and Moves
  • The Solar Atmospheres Greenville, South Carolina, facility recently announced that Gabriel Giraldo accepted the position of Sales Engineer and will be
    Kip Bailey, Field Service Technician, Bloom Engineering
    responsible for supporting relationships with existing customers and developing new business within the region. Prior to accepting this position, Giraldo worked in the heat treat industry as a mechanical engineer serving a broad spectrum of metalworking industry sectors, including aerospace and defense.
  • Bloom Engineering recently welcomed Mr. Kip Bailey as a full-time Field Service Technician. Mr. Bailey brings experience in both combustion and specific process knowledge via his work as a furnace builder.
  • Sue Harrod has been appointed chief operating officer (COO) of Diablo Furnaces LLC, a Machesney Park, Illinois-based, company that manufactures, refurbishes, upgrades, services, and supplies parts for atmospheric heat-treating equipment. Harrod has worked in the thermal-processing industry for 25 years in supporting and leading roles at BeaverMatic, Ipsen, and Diablo Furnaces.
Equipment Transactions
  • German heat-treating systems manufacturer IVA Schmetz received a new order for five vacuum hardening furnaces from Taiwan to be delivered to a leading steel supplier with
    IVA Schmetz delivered five vacuum hardening furnaces
    various locations throughout the country. IVA Schmetz is supported by the local partner Pan Folks, who is also responsible for commissioning the furnaces. The order is part of a larger investment project which also includes seven vacuum annealing furnaces delivered by IVA Schemtz's sister company BMI in France.
  • Hirschvogel Automotive Group from Denklingen in Bavaria and Sacotec Components Oy in Finland, a company specializing in
    Cast link belt furnaces from Slovenian industrial furnace manufacturer Bosi
    precision steel casting, each ordered cast link belt furnaces from Slovenian industrial furnace manufacturer Bosio, part of the Aichelin Group. A cast link belt furnace more than 22 meters in length with a performance of two tons of forged parts per hour went to Hirschvogel. Sacotec's order was for a shaft furnace for carburization of small parts.
  • An electrically heated, gas nitriding, pit furnace with an ammonia dissociator system for heat treating parts has been shipped to a technology manufacturer by Lindberg/MPH.  The pit furnace has a maximum temperature rating of 1250°F and work chamber dimensions of 28" diameter x 36" depth.
  • Shougang Jingtang United Iron & Steel, China, contracted Fives to design and supply a new galvanizing line furnace and inductors dedicated to the production of ultra high-strength steels at its Caofeidian facility. This is the sixth Fives furnace at this location.
  • Pirson Refractories installed the hearth refractory lining of Blast Furnace 2 at Arcelor Mittal Bremen.
Accreditations, Certifications, Patents, and More
Solar Atmospheres Western PA adds tensile testing
  • Solar Atmospheres of Western PA expanded its mechanical testing capabilities to include tensile testing. In the summer of 2017, Solar tookdelivery of a new Tinius Olsen 300SL Universal testing machine, as well as a new Haas Model TL-1 CNC lathe in order to custom machine test specimens. Currently, many aerospace specifications demand at least one tensile test to be performed on each heat lot of material and/or for every furnace load of components being heat treated. Previously outsourcing tensile testing, Solar is now able to avoid delay due to shipping and transporting test specimens to these labora
    Karen Stanton, owner and director of HTA Group
    tories.
  • Heat Treatment Australia (HTA Group) and its corporate and strategy director Karen Stanton were recently featured in a news article, "Risks Paying Off in a New Age of Manufacturing", published in Australia's Courier-Mail, drawing attention to the firm's investment "in research and development and machinery to position itself to become part of the multinational Joint Strike Fighter program" as part of a nationwide growth in manufacturing.
  • High-performance tubing supplier Fine Tubes announced it received Nadcap accreditation for fluid distribution systems.
    Phil Adderley, Director, Quality & Technical, and Rob Eatwell, QA Manager, for Fine Tues with fifth Nadcap Accreditation Certificate
    The Plymouth, UK-based, company already holds accreditations for heat treating, non-destructive testing, fusion welding, and chemical processing, and the five achievements qualify Fine Tubes for the industry-recognized AS5620 industry standard required by Boeing for its suppliers of titanium hydraulic tubing.
  • Ipsen was awarded U.S. Patent No. 9,719,149 B2 for the development of a new load transport mechanism that can move a load within a multi-station heat-treating system. Named inventors on the patent, Chief Engineer Craig Moller, Director of Engineering and Supply Chain Kevin Woerner, and Dr. W. Hendrik Grobler began developing this design five years ago.
  • Dana Incorporated was named Supplier of the Year by Blue Bird Corporation, a leading independent designer and manufacturer of school buses. Dana earned this top honor by introducing new products that align with Blue Bird's commitment to delivering innovative, market-leading technologies. Dana supplies Blue Bird with a complete range of drivetrain solutions including Spicer® medium- and heavy-duty single-drive axles, SPL® Series driveshafts, and Spicer end yokes.
  • Wisconsin Oven Corporation announced the company is pursuing new patents for equipment most commonly used in the aerospace industry, as well as a patent for “intelligent” oven technology, where the oven is able to monitor certain processes.
Quick Heat Treat News Chatter Items To Keep You Current Read More »
Mobile Heat Treatment Launch Targets Aerospace, Motorsports Customers
Ian Perks, Sales Director, Alloy Heat Treatment
Alloy Heat Treatment (AHT), a specialist in the heat treatment of aluminum alloy, has developed and is set to launch an innovative mobile heat treatment service.
The Dudley-based (UK) firm, a member of the manufacturing alliance Made in the Midlands, is targeting the new service in support of the additive layer manufacturing market in the UK and Europe, especially in the aerospace and motorsport (F1 and MotoGP) sectors.
“The proposed service is currently being designed to be transported on the back of a fix-bed lorry,” said sales director Ian Perks. “We aim to fill a gap in the AM market, as we feel that this innovation will provide a great benefit to aerospace, F1 and Moto GP organisations; and with the global AM market predicted to be worth more than $6.6 billion by 2026, we are hopeful that the service will attract plenty of interest.”
AHT would load the service onto a truck and then drive to a customer’s designated location to enable them to offer rapid heat treatment processes within tight schedules.
Mobile Heat Treatment Launch Targets Aerospace, Motorsports Customers Read More »
