2 VPA Furnaces Elevate Jet Manufacturer’s Heat Treat
In a move aimed at elevating its manufacturing capabilities, a leading jet engine manufacturer is gearing up to integrate two vapor phase aluminizing (VPA) coating furnaces during the first half of 2024.
These high-capacity, low-maintenance automated retort VPA furnaces from G-M Enterprises, a Nitrex company, are purposefully engineered with moving bases and a fixed heat chamber, enhancing operational efficiency. Each retort is sealed to the moving bases, allowing for concurrent handling of two loads, each containing three coating cans. The result is a streamlined process that runs two cycles back-to-back, completing the treatment in just over 24 hours. The automated furnace supports unattended start-ups, empowering operators to focus on preparing loads for the second system which facilitates concurrent operations for heightened productivity.
Source: Nitrex
Robert Huckins, national sales manager at G-M Enterprises, emphasized that the "VPA furnaces ensure seamless operations, providing our customer with a competitive edge in production capacity. This is crucial in meeting escalating demand while delivering high-performance and longer-lasting blades and vanes vital for high-temperature fired engines.”
A feature of the VPA design is the raised fixed heat chamber, effectively shielding operators and the furnace room against potential heat exposure. This innovation eliminates the need for cumbersome protective heat suits. The hot retort remains securely housed within the insulated furnace, prioritizing operator well-being. Furthermore, this safety measure confines the load base and retort/coating load within the SAR/VPA furnace housing until the retort temperature drops below 150°C (300°F).
This strategic investment not only underscores the manufacturer’s commitment to staying at the forefront of technological advancements but also solidifies a lasting partnership.
2 VPA Furnaces Elevate Jet Manufacturer’s Heat Treat Read More »
