Vacu-Braze
Equipment
Company & Personnel
Kudos
Large-Capacity Nitriding Furnace Enhances Processing Capabilities
The furnace features a working chamber of 48″ in diameter and 108″ in depth, more than doubling the company’s current processing volume. It can accommodate larger workloads while meeting AMS2759/6 requirements for aerospace nitriding applications that require strict control of compound layer formation, case depth, and process uniformity.
In addition to conventional gas nitriding, the new furnace enables ferritic nitrocarburizing, providing an additional surface engineering option in many alloy steels. Along with advanced pyrometry and temperature uniformity controls, these features ensure compliance with AMS2750 for critical applications.
With this addition, Vacu-Braze can process a broader range of part sizes while maintaining process control and consistency.
Large-Capacity Nitriding Furnace Enhances Processing Capabilities Read More »
