December 2015
Brazing to form strong metallurgical bond where the brazed joint becomes a sandwich of different layers, each linked at the grain level
The conversation explores various reasons why a vacuum furnace is well-suited to perform brazing because it provides:
  • a controlled, consistent atmosphere cycle after cycle
  • uniform heating throughout the hot zone
  • a controlled rate of heating
  • the elimination of air to prevent the formation of oxidation of the metal
Brazing applications from parts to rockets
February 2016
April 2016
Additional Notes on Titanium
February 2013
175,000 pounds of 6Al-4V titanium in Solar’s 48-foot-long vacuum furnace
Voices in Heat Treat: Vacuum Brazing Revisited Read More »
