Aluminum Processing Growth
FIgure 1. Critical temperature phase transitions of the T6 aluminum heat treatment process
Source: PhoenixTM
Figure 2. Thru-process temperature monitoring of the three T6 heat treatment phases
Source: PhoenixTM
Figure 3. Thru-process temperature profiling system installed in the product cage monitoring the T6 heat treatment (solution treatment, quench, and age hardening) of aluminum engine blocks
Thermal Protection Technology
Figure 4. TS06 thermal barrier design showing water tank, housing the data logger at its core, installed within structural frame containing the insulation blanket surface layer; water tank shown with traditional compression fitting face plate seal
Source: PhoenixTM
Figure 5. TS06 thermal barrier IP67 bi-directional rubber gasket seal; installation of mineral-insulated (MI) thermocouples and RF antenna aerial
Figure 6. View of TUS for T6 aluminum processing in Phase 1 Solution Re-heat
Source: PhoenixTM
Summary
Dr Steve Offley (“Dr O”), Product Marketing Manager, PhoenixTM
For more information: Contact Steve at Steve.Offley@phoenixtm.com.
