December 2015
The conversation explores various reasons why a vacuum furnace is well-suited to perform brazing because it provides:
- a controlled, consistent atmosphere cycle after cycle
- uniform heating throughout the hot zone
- a controlled rate of heating
- the elimination of air to prevent the formation of oxidation of the metal
February 2016
April 2016
Additional Notes on Titanium
February 2013
Founder & CEO
Solar Atmospheres, Solar Manufacturing
Source: Solar Atmospheres
Vice President of Operations, Souderton plant
Solar Atmospheres
Sales Manager of the Southeast
Solar Atmospheres, Inc.
Senior Vice President
Solar Manufacturing, Inc.
Source: LinkedIn
Voices in Heat Treat: Vacuum Brazing Revisited Read More »
