News from Abroad: Electric Steelmaking, Specialty Metals, and Additive Manufacturing
In today’s News from Abroad installment, we highlight several global developments in thermal processing — from major electric steelmaking projects and increased specialty steel remelting capacity to new capabilities for metal powder development and additive manufacturing — reflecting continued investment in production efficiency, advanced materials, and next-generation manufacturing technologies.
New EAF Boosts High-Grade Steelmaking Capacity
The new furnace will be the second Consteel EAF installed at the Hirohata Works.
“Tenova is to supply Nippon Steel’s Hirohata plant in Japan with an electric arc furnace (EAF). The contract was awarded through Daido Steel, the engineering, procurement, and construction (EPC) contractor.”
“Designed for the production of high-grade steels through electric steelmaking, the new furnace will have a heat size of 100 tons. Combining continuous scrap preheating with advanced automation systems, the new EAF will optimize energy consumption, melting performance, and process stability.”
Read more: “Tenova to supply furnace to Nippon Steel” at furnaces-international.com.
Electric Arc Furnace Nears Next Phase of Development
The EAF in Linz will produce 1.6 million tons of steel annually and is scheduled for startup in the first half of 2027.
“Primetals has delivered electric arc furnace (EAF) equipment to voestalpine’s steelmaking site in Linz, Austria. The delivery included the transformers, each weighing approximately 160 tons, and the electric arc furnace shell.”
“Powered by green electricity, the EAF in Linz will produce 1.6 million tons of steel annually and is scheduled for startup in the first half of 2027. Primetals is supplying the complete EAF Ultimate equipment, a dedusting system, a waste-heat recovery system, a power supply solution, and material handling for alloying materials and additives.”
Read more: “Primetals delivers equipment for voestalpine furnace” at furnaces-international.com.
Remelting Capacity Doubles for High-Nitrogen Steel
The new DESU system was installed at Energietechnik Essen.
“Energietechnik Essen GmbH (ETE), a company of the GMH Group, has inaugurated its second pressure electroslag remelting (DESU) plant in Essen. The new plant doubles ETE’s annual DESU delivery capacity from approximately 1,300 to at least 2,600 tons.”
“The new DESU system operates at pressures of up to 40 bar and, depending on the diameter, can produce blocks with a diameter of 430 to 1,000 mm and a weight of 2 to 18.5 tons.”
Read more: “Energietechnik Essen doubles DESU capacity for Cronidur® 30 and high nitrogen steels (HNS®)” at heat-processing.com.
Metal Powder Developer Adds In-House LPBF Capability
Alexander Höhne, managing director of MTS Metal Powder GmbH & Co. KG (left), and Won-jong Kim, CEO of DN Solutions (right), stand in front of the DLX150 metal 3D printer at AMB 2026 in Stuttgart.
“DN Solutions is supplying the German metal powder manufacturer MTS Metal Powder GmbH & Co. KG with a DLX150 metal 3D printer.”
“By combining additive processes with downstream machining and other post-processing steps within a holistic manufacturing approach, DN Solutions covers the entire process chain—from powder to finished component.”
Read more: “DN Solutions supplies MTS Metal Powder with the DLX150 metal 3D printer” at heat-processing.com.
