Manufacturing Technical Content
Ask The Heat Treat Doctor®: Hot Topic for a Cold Day — Why Is Hot Gaseous Corrosion So Devastating?
Ask The Heat Treat Doctor® has returned to bring sage advice to Heat Treat Today readers, answer questions about heat treating, brazing, sintering, ...
Today's Technical Tuesday highlights this first installment in a multi-part series by Nikolai Alexander and The Heat Treat Doctor® Daniel H. ...
Q&A: AI, MCP, and Heat Treat
AI is moving from concept to practice in heat treating — driving furnace optimization, smarter scheduling, and predictive compliance. In this ...
CO2-Neutral Heat Generation Technology Progress
A new study from the Umweltbundesamt (the Federal Environment Agency in Germany) outlines a clear, technically grounded pathway for achieving CO2-neutral ...
Austenización Insuficiente en el Tratamiento Térmico: Causas, Efectos y Cómo evitarla
Un austenizado insuficiente afecta mucho más que la dureza final. Interrumpe la transformación de fase, debilita el rendimiento mecánico y aumenta ...
Insufficient Austenitizing in Steel Heat Treatment: Causes, Effects, and How to Prevent It
Insufficient austenitizing affects far more than final hardness. It disrupts phase transformation, weakens mechanical performance, and increases the risk of distortion ...
Hybrid Heating Systems Unlock Heat Process Decarbonization
As pressure mounts to cut industrial CO2 emissions, hybrid heating systems are emerging as a compelling pathway to decarbonizing industrial process ...
Case Study: Waste Heat Recovery & Digital Innovation Cut Cycle Times
What if your furnace could run faster, cheaper, and cleaner — without major capital investment? Carl Nicolia, president at PSNERGY, LLC, ...
Heat Treat Radio #129: Understanding US Energy Initiatives and Their Impact on Heat Treating
In this episode of Heat Treat Radio, Doug Glenn sits down with Michael Mouilleseaux of Erie Steel Treating to examine U.S. energy ...
Heat Treat Radio #128: Silicon Carbide Without Transformers: How Is That Possible?
In this episode of Heat Treat Radio, Tony Busch of Control Concepts, Christina Clowes of I Squared R, and Dr. Stephen Feldbauer ...
Pit LPC: A Modern Take on High Throughput Heat Treat
Producing durable, wear-resistant gears for the wind turbine industry requires exacting control of carbon diffusion. Modern low pressure carburizing (LPC) is ...
Flame and Fire: History of the Industrial Gas Industry
Jim Roberts of U.S. Ignition entertains readers in a Combustion Corner editorial about how the industrial gas industry evolved from its ...
Ask The Heat Treat Doctor®: What Masks the Steel’s Surface in Case Hardening?
Ask The Heat Treat Doctor® has returned to bring sage advice to Heat Treat Today readers and to answer your questions about heat ...
Sigma Phase Metallurgy 101
In this Technical Tuesday installment, Nick Hicks, metallurgical services manager at Rolled Alloys, emphasizes the importance of mastering the basics of ...
Heat Treat Radio #127: The Case for Modular Vacuum Heat Treating
In this episode of Heat Treat Radio, host Doug Glenn invites Dennis Beauchesne of ECM USA to explore the technology, benefits, scalability, ...
What’s the Rebricking and Relining Process for My Atmosphere Furnace?
This Technical Tuesday installment is part of the Maintenance Message column series. In today's edition Nate Sroka, quality assurance engineer for ...
Will In-House Heat Treaters 3D Print the “Cutting Edge”?
If you are one of many heat treat professionals watching AM take over the industrial world with bated breath, it may ...
The Future Is Coming Three Times Faster Than You Think
In this Technical Tuesday installment featuring Combustion Corner by Jim Roberts, president of U.S. Ignition, readers are enlightened about how upcoming ...
From Furnace To Your Front Door: A Morning in Heat Treatment
Heat treatment impacts almost every facet of our lives, yet few people are aware of how important this practice is to ...
AM/3D Trivia
In today's Technical Tuesday installment, we highlight the various techniques and developments in the world of metal AM as it pertains ...
Experts Anticipate Key Heat Treat Technology Adoptions
Industry experts agree: 2025 is a year of significant, high-tech developments. In this Technical Tuesday, hear from three heat treat industry ...
Ask the Heat Treat Doctor®: What Does “Bright and Shiny” Really Mean?
The Heat Treat Doctor® has returned to offer sage advice to Heat Treat Today readers and to answer your questions about heat treating, ...
Anatomy of a Front-Loading Vacuum Furnace
Contact us with your Reader Feedback! How well do you know the “anatomy” of your key heat treat equipment? In this ...
Evolving Efficiency: Advantages of Multi-Chamber Isolated Heat Vacuum Furnaces
Adapting to new processing demands puts traditional equipment to the test. Can single-chamber solutions keep up, or will applications require different ...
The heat treat industry is rich with knowledgeable leaders, resourceful problem solvers, and innovative teams. One of our favorite things to ...
Consulta a The Heat Treat Doctor®:¿Cómo determinar cuál medio detemple utilizar?
The Heat Treat Doctor® ha vuelto para ofrecer sabios consejos a los lectores de Heat Treat Today y para responder a suspreguntas sobre ...
Ask the Heat Treat Doctor®: How Does One Determine Which Quench Medium To Use?
Tech Round Up: Helpful, Readable, and Applicable Content
On just about any given Tuesday, Heat Treat Today features an article that aims to educate our heat treating readers — be ...
Maintenance Message: Extending the Service Life of Refractory Linings
Heat treating aluminum presents a unique concern due to the operating conditions of high temperature, chemical corrosion, mechanical abrasion, and temperature ...
How To Tell If You Really Have an Abrasion Problem
Understanding abrasion can be the key to extending the life of your refractory lining. The following article provided by Plibrico Company examines ...
Heat Treat Radio #111: Heat Treat NextGen Brynna Keelin Kelly-McGrath
If curiosity were a person, Brynna Keelin Kelly-McGrath would be her name. Having risen at Moog, Inc. to the position of ...
How To Reduce Carbon Footprint During Heat Treatment
Given changing ecological and economic conditions, carbon neutrality is becoming more important, and the heat treatment shop is no exception. In ...
Source: TAV Vacuum Furnaces When processing cemented carbide, there are a few considerations you need to understand to use the proper ...
Heat Treating AM Components to Infinity and Beyond
The amazing materials that are produced through additive manufacturing (AM) and 3D machining often require post-processing heat treatments before these become ...
Message from the Editor: Digitalization: An Ever-Expanding Frontier
Heat Treat Today publishes eight print magazines a year, and included in each is a letter from the editor, Bethany Leone. ...
Heat Treat Radio #108: Heat Treat NextGen Humberto Ramos Fernández
A leading heat treat and HIP processing director, Humberto Ramos Fernández has overcome business and technologic challenges to make HT-MX the successful commercial heat treat ...
The Melting Point: Lesson on Eutectic Reactions
What is the most common scenario for a eutectic reaction? And (for that matter) what constitutes a eutectic reaction? Contact us ...
CUI Considerations for the Heat Treating Industry
2024 is a big year for heat treaters who work for the DoD. As Joe Coleman, cybersecurity officer at Bluestreak Consulting, explains, ...
Sustainability Insights: How Can We Work To Get The Carbon Out Of Heating? Part 2
The search for sustainable solutions in the heat treat industry is at the forefront of research for industry experts. Michael Stowe, PE, ...
Heat Treat Radio #106: Heat Treat Legend Doug Peters
"Don't lose sight of who you are . . . ." In an industry where passion to create, help, and discover ...
Exo Gas Composition Changes, Part 2: Cool Down and Use in Heat Treat Furnaces
In Part 1, the author underscored the importance of understanding the changes in gas composition through three steps of its production: ...
Heat Treat Radio #105: Lunch and Learn: Batch IQ Vs. Continuous Pusher, Part 2
Have you decided to purchase batch or continuous furnace system equipment? Today's episode is part 2 of the Heat Treat Radio ...
Sustainability Insights: How Can We Work to Get the Carbon Out of Heating? Part 1
The search for sustainable solutions in the heat treat industry is at the forefront of research for industry experts. Michael Stowe, ...
Continuing the Dialogue: Michael Mouilleseaux on Batch/Continuous Furnace Maintenance
Our readers and Heat Treat Radiolisteners will remember a recent episode entitled "Heat Treat Radio #102: Lunch & Learn, Batch IQ ...
An Overview of Case Hardening: Which Is Best for Your Operations?
Source: Advanced Heat Treat Corp. Case hardening is an essential process for many heat treating operations, but knowing the different types ...
Are there rapid changes in the North American aluminum industry to accommodate trending technology, or does the aluminum market have a ...
Accurate hardness testing is a critical business for numerous industries, not least heat treatment. In this guide, we will offer our ...
It’s Time for Another Look at Vacuum Oil Quenching
Oil quenching can be a dirty phrase around the heat treat shop. But with vacuum, does it have to be? This ...
Listen To Vacuum Heat Treat on the Radio Waves
There's always more to learn, and at Heat Treat Today, we strive to help you be well informed. Thanks to our ...
Heat Treat Radio #103: US Army Veteran MG T.J. Wright — From Vietnam to Heat Treat
MG Timothy J. Wright (T.J. Wright) understands the heat from a heat treat furnace as well as the heat of engagement ...
Half-a-Dozen Vacuum Heat Treat Tips
Let's discover new tricks and old tips on how to best serve vacuum furnace systems. In this print edition, Heat Treat ...
The Canary in the Furnace: Ceramic Disks Give Early Alerts of Temperature Changes
The question in many heat treaters' minds is, "Why would I want more documentation on my furnaces?" TempTABs can act as ...
Sustainability Insights: Vacuum Heat Treating in a Carbon-Conscious Market
Reducing the industrial carbon footprint has been at the forefront of much discussion, heat treat industry-specific or otherwise. How can heat ...
“Quench” Your Thirst: 3 Technical Articles To Satisfy Your Needs
Thirsting for knowledge about quenching, but not sure where to start? Heat Treat Today has coalesced technical information across articles and ...
Sustainability Insights: Process Heating and the Energy-Carbon Connection
"Plan, do, check, act." When it comes to caring about carbon footprint, a path forward to may seem too out-of-reach. But ...
Optimize Working Life and Performance of Heat Treatment Alloy Castings
When it comes to optimizing the working life and overall performance of heat treatment alloy castings, proper alloy selection and design ...
Vacuum Furnaces: Origin, Theory, and Parts
Vacuum furnaces are widely used in the aerospace and automotive industries. These furnaces are used for multiple processes including brazing, aging, ...
Top 3 Heat Treat Grab and Go Visuals
We get it. You read all day: emails, memos, furnace monitoring screens. To give your eyes a break, Heat Treat Today wanted ...
Heat Treat Radio #64: Thermocouple 101 with John Niggle, Pelican Wire (Part 3 of 3)
Heat Treat Today publisher Doug Glenn wraps up this three-part series with Pelican Wire experts by talking with John Niggle from Pelican ...
Natural Gas vs. Hydrogen Combustion: Reality or Hot Air? – Expert Analysis
Fossil fuels. Are they detrimental to the environment? Are they past their prime? Is hydrogen what we should be talking about? ...
Furnace Gas Composition Controlled with CO and CO2
Source: AZO Sensors Many heat treat processes require protective or process gases. These gases often require careful monitoring. ...
Heat Treat Tips: Atmosphere Control
