Aluminum Brazing Furnace Supports Automotive Industry
Weifang Hengtong Radiator is increasing their efficiency and quality of their aluminum plate and bar heat exchangers with a semi-continuous controlled atmosphere brazing (CAB) furnace at their in-house heat treat operations.
Piotr Skarbiński
SECO/WARWICK
The SECO/WARWICK furnace was specifically designed for the production of plate & bar heat exchangers. The semi-continuous CAB system is based on a multi-stage cycle division. The line includes: a drying furnace, an entry washing chamber, a convection preheating and brazing chamber, an intermediate air seal cooling chamber, and a final direct cooling chamber. The semi-continuous mode ensures that even large-sized components are evenly heated during the proper process time.
“The semi-continuous Universal CAB System ensures shorter cycle time, lower investment costs, and higher process efficiency of each batch. These are the main advantages of the CAB system compared to vacuum brazing furnaces,” says Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment at SECO/WARWICK Group.
The furnace is characterized by high flexibility, allowing the brazing of exchangers of various masses and dimensions in subsequent cycles while maintaining process parameters.
Aluminum Brazing Furnace Supports Automotive Industry Read More »
