Shijiazhuang Iron & Steel Company
15 Quick Heat Treat News Chatter Items to Keep You Current
Personnel & Company Chatter
  • A long-term agreement to supply materials used in the manufacture of naval nuclear reactor components has been signed between BWX Technologies, Inc., and Allegheny Technologies Incorporated.
  • Kennametal Inc. announced that it has formed a 3D printing materials and production business unit, Kennametal Additive Manufacturing, as part of its infrastructure segment. The new business unit combines the company’s longstanding expertise in materials science and wear-resistant solutions with additive manufacturing capabilities to supply high-performance metal additive powders and fully finished 3D printed parts for wear, erosion, corrosion, and high-temperature applications.
  • StandardAero Component Services celebrated the grand opening of the company’s 30,000 sq. ft. expansion of its Hillsboro, Ohio, engine component manufacturing and engine component repair facility. The additional working space and capital improvements included the building and additional equipment to support aerospace engine low-pressure turbine vane manufacturing. The Hillsboro location expansion completes StandardAero’s current plans for new building and expansion investments, which have also occurred at its Cincinnati, Miami and Kansas City locations over the last 18 months.
  • A 30-ton tilting rotary furnace for aluminum recycling was installed by GHI at the new facility of Latem Aluminium in Villadangos, Spain.
  • No. 965, a 1350ºF (~733ºC) electrically-heated cabinet oven from Grieve, has been purchased for heat treating titanium at the customer’s facility.
  • Tangshan Zhengfeng Iron & Steel Co., LTD, in Hebei Province, China, recently commissioned three iRecovery® (intelligent waste heat recovery systems) from Tenova, a Techint Group company. Tenova iRecovery® systems will be applied downstream of the new Consteel® Evolution to recover the waste heat and to use it for the production of steam, which will then be available for the existing power plant.
  • A vacuum drying oven has been shipped to the aerospace industry by Tenney Environmental, a division of Thermal Product Solutions. This vacuum drying oven is designed to remove moisture from a large spacecraft engine after it goes through a washing process. The previous conventional method of drying took over 12 hours due to the intricacy of small diameter tubing, fine screen meshes, and other hard to get to areas. The vacuum drying oven will reduce that time to 4 hours. This vacuum drying oven utilizes radiant heat wrapped around the pressure walls to heat the product to approximately 100°F.
  • An electrically heated two-zone bottom flow conveyor oven was shipped to the consumer goods industry by Wisconsin Oven. This belt conveyor oven will be used to cure a latex barrier coating onto maple syrup bottles.
  • Exlabesa, an aluminum extrusion provider for the construction industry in Europe, recently ordered a multi-chamber PR130 melting furnace (complete with charging unit) for its Hertwich continuous homogenizing plant at its Padron (Spain) based facility. This furnace will increase its capacity to 60,000 tons from its Padron casthouse. The new furnace with a capacity of 130 tons per day is designed for a relatively wide range of scrap.  The temperature level in the main chamber from which the melt is tapped for casting is about 1800°F (1000°C).
  • Walsin Yantai Stainless Steel Co. Ltd. has contracted with Primetals Technologies to design and manufacture a new stainless steel combination mill to convert billets from an existing plant into finished products with precision tolerance and surface quality. Located in Yantai, Shandong Province, China, the new mill project with Primetals Technologies will be completed in consortium with CERI Long Product Co. Ltd., including all electrics and automation to approach Industry 4.0. The combination mill will have a straight bar outlet, a bar-in-coil outlet, and a wire rod outlet.
  • A leading industrial engineering and manufacturing group recently completed several furnace projects for global clients. Fives was contracted by Habaş, a leading conglomerate in Turkey which operates in the field of industrial gases, steel, LPG, and heavy machine manufacturing, to design and supply a new generation slab reheating furnace, the Stein Digit@l Furnace®, for its hot strip mill, located in Izmir, Turkey. In addition, Shijiazhuang Iron & Steel Company within China’s HBIS Group ordered two Stein Digit@l Furnaces® from Fives to reheat blooms and billets. The walking beam furnace will have a production capacity of 130 tons per hour and will operate on natural gas. Fives was also selected by Yantai Walsin Stainless Steel to design and supply an ultra-low NOx emission furnace to reheat long products. Yantai Walsin Stainless Steel is a subsidiary of Walsin Lihwa, a world-leading manufacturer of stainless steel, power cables, and wires.
  • A 500°F (260°C) enhanced-duty walk-in oven was delivered by Lewco Inc., of Sandusky, Ohio, that will be used to dry various parts during a manufacturing process.
  • Sr. Quality Engineer)
  • Flash Steelworks, located in Washington, Michigan, provides a patented process for heat-treating steel that leads to mass reduction, performance improvement, and cost savings. This distinction gained them a position among 24 semi-finalists for the 10th annual Accelerate Michigan Innovation Competition, where the top prize is $350,000.
  • Materials Solutions, a Siemens company specialized in additive manufacturing (AM), has achieved Nadcap accreditation for AM in the aerospace industry. The accreditation is reportedly the first by a UK company. Materials Solutions, which has its headquarters in Worcester, has provided AM parts and components to the aerospace industry since its founding in 2006. The business is a pioneer in the use of selective laser melting (SLM) technology for the manufacture of high-performance metal parts. SLM applications in the Materials Solutions factory range from high-temperature components found in gas turbines and jet engines, to tooling applications as well as lightweight structural components and hydraulic applications.
15 Quick Heat Treat News Chatter Items to Keep You Current Read More »
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry.
  • TimkenSteel has announced that Ward J. “Tim” Timken, Jr. has stepped down as CEO and president and as chairman of the TimkenSteel board of directors. Effective immediately, the Board of Directors has appointed Terry L. Dunlap as the company’s interim CEO and president. John P. Reilly, the current lead director of the TimkenSteel board of directors, will immediately assume the role of chairman of the board.
  • Rick Merluzzi has been promoted to the position of CEO at Metal Exchange Corporation. Mike Lefton, current chairman and CEO, will assume the title of executive chairman. Merluzzi oversees all their businesses, including Metal Exchange Trading, Pennex Aluminum Company, Continental Aluminum and Electro Cycle, Inc.
  • Platte River Equity has sold its portfolio company PRV Metals to Tinicum LP. PRV Metals, a leading supplier of specialty forged titanium and high-performance steel products to aerospace, defense, medical, energy, and industrial sectors, operates through two subsidiaries Sierra Alloys and TSI Titanium.
  • US aviation group Collins Aerospace has extended the contracts for the supply of thrust reverser housings for the engine gondolas of the Airbus A350 XWB and Boeing 787 aircraft. The order includes the delivery of the engine cowlings into the next decade. This contract renewal is a major contribution to strengthening FACC’s position as an international partner in the Engines & Nacelles segment.
  • Bodycote Thermal Processing Inc has announced it will spend $15.3 million to renovate and equip a dilapidated, 58,000-square-foot building in Geddes, New York, to replace the company’s facility that burned down in Van Buren, New York, in 2018. Equipment will be purchased that will allow the company to perform heat treatment processes not currently available in the United States.
  • Element Materials Technology has announced that its new aerospace materials testing laboratory in Shanghai, China, is now open for business. Element confirmed it has completed a number of accreditations including ISO/IEC 17025:2017 and Nadcap, with OEM audits underway. The new laboratory specializes in a comprehensive range of services that include: chemical analysis; fatigue testing; failure investigation; mechanical testing; metallurgical analysis, and on-site testing at client sites. Customers will also benefit from pre-testing services, including a full machine shop and heat treatment furnaces for the treatment of materials prior to testing.
  • Construction is moving forward at a brisk pace at Stack Metallurgical Group‘s new Albany, Oregon site, where the company will offer both Hot Isostatic Pressing (HIP) and vacuum heat-treating services.
  • Three intelligent waste heat recovery systems have been awarded by Tangshan Zhengfeng Iron & Steel Co., LTD, in Hebei Province, China, to Tenova, a Techint Group company specializing in innovative solutions for the metals and mining industries.
  • A contract to supply on-site nitrogen to Samwha Capacitor’s new multi-layer ceramic capacitor (MLCC) plant being built adjacent to its existing plant in Yongin, South Korea, has been awarded to Air Products. Under the new contract, Air Products will expand its nitrogen capacity to support the increasing demand from Samwha Capacitor’s existing and new plants.
  • Advanced soft magnetic expertise and ultra-efficient electrical components will be provided by Carpenter Technology to multiple OEMs to progress their electric aircraft aspirations.  Carpenter Technology will provide advanced soft magnetic expertise and ultra-efficient electrical components to be used in R&D and demonstrator motors and engines, leading to construction of lighter-weight, longer-lasting electric propulsion systems.
  • Two reheating furnaces to reheat blooms and billets have been delivered to Shijiazhuang Iron & Steel Company within China’s HBIS Group by Fives.
  • Element Materials Technology has been awarded the 2018 Gold Boeing Performance Excellence Award (BPEA) for its Huntington Beach, California, laboratory, while the Element Los Angeles laboratory won Silver. The annual award recognizes superior performance in the highest tiers of Boeing’s supply chain. This is the second year Element Huntington Beach has achieved the Gold award and the first year that Element Los Angeles has achieved Silver status.
  • Plibrico Corporation has awarded employees Joe Feldhacker, a project manager from Plibrico’s Omaha, Nebraska location, and Lou Calderon, refractory CAD designer in the company’s engineering department in Northbrook, Illinois, API 936 Refractory Personnel Certification. Both demonstrated advanced knowledge of installation, inspection, testing and repair of monolithic refractory linings, passing the rigorous API 936 exam administered by the American Petroleum Institute (API), a national trade association representing all facets of the natural gas and oil industry.
  • Spirit AeroSystems was recognised at the Composites and Advanced Materials Expo (CAMX) with the Award for Composite Excellence (ACE) in Manufacturing: Material and Process Innovation. Spirit received the award for its development of the Advanced Structures Technology and Revolutionary Architecture (ASTRA) demonstrator aircraft panel, which was displayed at the CAMX conference in Anaheim, California.
  • The 100th nacelle system for Airbus’ A330neo wide-body jetliner has been delivered by Safran Nacelles.
