Lush Heat Treatment Ltd.
Equipment
Company & Personnel
Kudos
Heat Treater Acquisition Enhances Integrated Manufacturing Capabilities
G.S. Precision, a precision machining and manufacturing company headquartered in Brattleboro, Vermont, has expanded its global manufacturing platform with the announcement of the acquisition of Lush Heat Treatment Ltd. and Headwater Precision, Inc., strengthening vertical integrated capabilities that support aerospace, defense, and other high-spec industries. The additions broaden the company’s technical scope across machining, coatings, and thermal processing, while extending the company’s geographic footprint in North America and Europe.
James R. Callan
Chief Executive Officer
G.S. Precision
Lush Heat Treatment, based in the United Kingdom, provides vacuum and endothermic heat treating services, as well as brazing services, for clients in the aerospace, defense, space, and nuclear power sectors. These processes support the performance requirements of critical components operating in demanding environments.
Headwater Precision, located in New Hampshire, is a precision manufacturing and advanced coating technologies business serving clients in aerospace defense, semiconductor, and industrial markets.
By bringing these capabilities together, G.S. Precision is positioning its company to offer a more integrated manufacturing approach, combining machining, surface treatment, and heat treating within a single organizational structure.
James R. Callan, chief executive officer of G.S. Precision, said the acquisitions align with the company’s growth strategy, adding capabilities such as advanced coatings and specialized heat treating to better support clients producing mission-critical components.
Heat Treater Acquisition Enhances Integrated Manufacturing Capabilities Read More »
