- Advanced Heat Treat Corp (AHT), which provides heat treat services and metallurgical solutions, announced today the addition of three new sales and marketing employees: Vasko Popovski, Jason Taylor, and Lindsey Newcomb. Popovski will focus on heat treat needs in the Great Lakes area. Taylor will cover sales in the southeast region of the country. Newcomb, Marketing Manager in the corporate office located in Iowa
- OMG Inc. recently announced four promotions in supply-chain management and operations: Wayne Ringenbach was promoted to director of Manufacturing, which includes heat treating; Brad Bedard was promoted to director of Supply Chain Management; Chris Mowatt was promoted to director of Manufacturing Engineering; and Geri McCarthy was promoted to director of Operations.
- Samuel, Son & Co., Mississauga, Ontario, has acquired Sierra Aluminum, Riverside, California. Sierra is a supplier of aluminum extrusions and related products to a number of end markets, including construction and transportation. Sachin Shivaram has been named president of Sierra Aluminum Group, following Ed Harris’s decision to retire from the company.
Marketing Manager
Advanced Heat Treat Corp.
- A heat treating equipment supplier based in Plymouth, Michigan, recently shipped a pair of 36” x 48” x 36” electrically heated temper furnaces to a major drive supplier in the Southeast. Gasbarre Furnace Group/J. L. Becker designed the furnaces, which operate from 300°F to 850°F with a temperature uniformity of ±5°F, to preheat workloads prior to hardening and temper workloads after hardening.
- An India-based conglomerate recently contracted Can-Eng Furnaces International Limited to design, manufacture, install, and commission an aluminum automotive casting heat treatment system for its new greenfield North American expansion in South Carolina. The new system will service three distinct aluminum product groups with unique treatment cycles.
- A global manufacturer of thermal-processing equipment recently shipped a custom Gruenberg bench oven to the movable machinery industry. The bench oven is rated for Class B operation per the NFPA 86 specifications. Thermal Product Solutions (TPS) designed this bench oven to be used in the customer’s testing and product development department to process various mechanical apparatuses affixed to a Ling Dynamic Electronic Shaker. The maximum temperature rating of this Class B oven is 1022°F (550°C) and the work chamber dimensions are 36” W x 36” D x 36” H. In addition, TPS delivered a Gruenberg cabinet oven to the research and development industry. This Class B oven will process up to 5 gallons of water per batch from 1500 lbs of metal powder. The maximum temperature rating of this Class B cabinet oven is 250° F and the work chamber dimensions are 48” W x 48” D x 48” H. Both Gruenberg ovens are constructed from a structural steel frame that supports the fully welded 304 stainless steel chamber liner and the exterior sheet metal.
- Grieve has built a 1,250°F, horizontal airflow cabinet oven used for heat treating at the customer’s facility. With workspace dimensions of 38" by 38" by 38", it has 12"-thick insulated walls comprising 2" of 2,300°F ceramic blanket and 10" of 10 lb./cu. ft. density Rockwool.
- A vacuum space simulation system was recently shipped to a company that manufactures equipment for space. Tenney Environmental designed this system to test ionic thruster chips for space vehicle systems. The simulator will allow the customer to test their products in-house, while replicating outer space conditions. The dual cryopump vacuum system is sized specifically to maintain the high vacuum while the thrusters are firing inside the vessel.
- An industrial manufacturer recently purchased a custom car bottom furnace from LEWCO, based in Sandusky, Ohio. The electrically heated oven, which is rated for a maximum temperature of 1,300°F., is used for annealing steel parts, featuring a workspace of 72”W x 140”D x 90”H, and manufactured and designed to NFPA 86 “Class B” standards.
- Liebherr-Aerospace Toulouse SAS, center of excellence for aerospace air management systems within the Liebherr Group, has obtained accreditation from NADCAP (National Aerospace and Defense Contractors Accreditation Program) for its Materials Testing Laboratory.
- A leading provider of vacuum impregnation technology, Godfrey & Wing, passed its transition audit for ISO 9001:2015/IATF 16949 certification from Smithers Quality Assessments (SQA), an accredited third-party registrar. The IATF 16949:2016 certification is the recently published revision to ISO/TS 16949: 2009, one of the most widely used international standards in the automotive industry. The standard acts as a supplement to ISO 9001: 2015 for automotive quality management systems.
- Bonnell Aluminum, a subsidiary of Tredegar Corporation also recently announced that its aluminum extrusion manufacturing facility in Newnan, Georgia, has achieved certification under IATF 16949:2016.
- In January of 2018, Logik Precision Inc. (LPI), a CNC machining, water jet, EDM and welding/fabrication service provider primarily operating in the oil & gas industry, selected QMSC, which provides quality management consulting services and is the developer of QMS, to provide professional consulting services to transition the organization from ISO 9001:2008 to the current revision of 2015. QMSC performed gap audit, completed revisions to the quality management system, performed employee training, and represented LPI during the registrar audit which was conducted on July 11th and 12th. Logik Precision successfully demonstrated compliance and commitment to its quality program. The audit was closed with zero findings and no observations. QMSC will provide ongoing fractional Quality Director services to assist LPI with continuous improvement.
