Bluewater Thermal Solutions Ships First Production for Energy Producer
Bluewater Thermal Solutions has announced its first production order of Hard-Corr™ tubing to a Texas-based energy producer. The order contains 12,000 feet of tubing and will be installed during well operations commencing this month.
The product is 2-7/8-inch diameter, 32-foot long, Grade L80 1% chromium steel production tubing treated with Bluewater’s proprietary Hard-Corr surface technology. The process imparts enhanced corrosion, wear, and erosion resistance to both the inner and outer surfaces of the tubing, making it ideal for annular and annulus production wells.
Technical Director
Source: Bluewater Thermal Solutions
“Our customers have relied on boronized tubing for years to combat corrosion and wear inside wells. Hard-Corr builds on that success offering enhanced protection compared to untreated tubing, plus added benefits and flexibility, at a lower overall cost,” said Craig Zimmerman, technical director for Bluewater Thermal Solutions.
While boronized tubing remains the established premium standard for inner-surface protection, Hard-Corr™ is engineered as a complementary, lower-cost alternative that maintains the mechanical integrity and strength of L80-grade steel. This allows operators to deploy it as a full-string solution from bottom to top while also gaining additional protection for the exterior surfaces.
The company is the largest supplier of boronized products and services to oil and gas producers in the Bakken and Permian shale plays.
Bluewater Thermal Solutions Ships First Production for Energy Producer Read More »
