Heat Treating Supports Aerospace Components for Artemis II Mission
Solar Atmospheres has provided thermal processing services for materials and components used in the Artemis II mission, supporting aerospace applications that require precise control of material properties and performance under extreme conditions.
Image Credit: Solar Atmospheres
The heat treater specializes in thermal processing of a range of materials, including raw stock, nickel-based tubing, and other aerospace components that play a vital role in bringing next-generation space technology to life.
Click on the image above to learn more about high-temperature materials used in space applications.
At the core of some of these components is the 6AI-4V titanium Launch Abort System (LAS), which is a complex safety system. The LAS aboard the Orion spacecraft functions as a rocket capable of outrunning another rocket in an emergency. In the event of a catastrophic launch anomaly, its manifold enables the abort motor to ignite and safely propel the crew module away from the rocket.
Components used in these applications must meet strict requirements for precision and reliability, with little margin for error in performance.
Heat Treating Supports Aerospace Components for Artemis II Mission Read More »
