Tool Manufacturer To Expand Heat Treat Capabilities with Pit Furnace
Lindberg/MPH, a manufacturer based in Michigan, shipped the steam treating furnace which has a maximum temperature rating of 1,250°F and work chamber dimensions of 22" diameter x 36" depth. The pit furnace is insulated with vacuum formed ceramic fiber modules that allow for rapid heat up rates and fast control response. A circulation fan distributes heat evenly throughout the chamber which ensures rapid and uniform heat transfer throughout the product load.
Tool Manufacturer To Expand Heat Treat Capabilities with Pit Furnace Read More »
