brazing heat treatment
Auto Parts manufacturer Adds EV/CAB Line
An auto parts manufacturer that specializes in the production of radiators and air conditioning systems recently ordered a fully electric furnace for brazing aluminum in a protective atmosphere. The EV/CAB line is designed for the production of tubular and plate-fin heat exchangers with uniform temperature distribution across the 1300 mm wide belt.
Piotr Skarbiński
SECO/WARWICK
SECO/WARWICK designed the uniform temperature distribution feature in the equipment to meet the company’s quality requirements of the finished products. The CAB line on order, the first this manufacturer has acquired from SECO/WARWICK, provides the continuous brazing of products with similar dimensions and features. The temperature is evenly distributed over the entire width of the belt due to several independent heating zones, resulting in long-term operation under industrial conditions.
“Uniform temperature distribution across the entire belt, regardless of how wide it is, is an important consideration influencing the final effect of the production,” said Piotr Skarbiński, vice president of the Aluminum Process and CAB Business Segment at SECO/WARWICK. “Our furnaces provide an optimal brazing temperature profile and a very clean atmosphere necessary to maintain high process quality. In China, we sell CAB lines for manufacturers of electric vehicle battery coolers, as well as for manufacturers of other heat exchangers. The furnaces on order by this partner are powered by electricity, making them ecological and free of CO2 emissions.”
Auto Parts manufacturer Adds EV/CAB Line Read More »
Cincinnati Radiator Bolsters Aluminum Brazing Capabilities with New VAB Furnace
Cincinnati Radiator, a manufacturer of radiators and cooling products, recently expanded its production capabilities at its Fairfield, Ohio, facility with the addition of a vacuum aluminum brazing (VAB) furnace. This acquisition will enable the company to perform in-house radiator core brazing.
The VAB furnace, with a weight capacity of up to 2,000 lbs, is the third manufactured and installed by Ipsen.
Prasenjit Ray
General Manager
Cincinnati Radiator
Source: Ipsen
“This furnace has so many recipes for us to use,” said Prasenjit Ray, general manager of Cincinnati Radiator. “We were planning to test it out for two months, but we weren’t expecting to get production-quality within those two months. What shocked and surprised me was that the first cores that came out were perfect. We’ve produced 10 (in the first month) and it runs like a new Cadillac.”
“We knew that we needed a way to make cores here. When customers had to rely on cores processed in China, it could mean a four-month lead time. If we had our own furnace, we could operate a just-in-time production,” said Ray. “We went with John Pease (Ipsen Regional Sales Representative) and Patrick McKenna (Ipsen USA President & CEO) to California to see a company operating two Ipsen VAB furnaces. Our team knew that, once we saw them in operation, we wanted to work with another company within the United States. Ipsen could offer great aftermarket support, and the delivery was worth the wait.”
Main image (left to right): All of Cincinnati Radiator: Abhilash Uppala, Manufacturing Engineer; Prasenjit Ray, General Manager; Michael Petitt, Assistant Operations Manager; and James “Tom” Aynes, Accounting Manager. Source: Ipsen.
Cincinnati Radiator Bolsters Aluminum Brazing Capabilities with New VAB Furnace Read More »
Vacuum Heat Treat Capabilities Expand for Magnetic Shields Ltd
Colin Woolger, Director, MSL Heat Treatment
Source: LinkedIn
A U.S. manufacturer of heat treat furnaces will supply a new vacuum furnace to the heat treat subsidiary of Magnetic Shields Limited (MSL) of Kent, United Kingdom. MSL Heat Treatment will use this furnace in the manufacture of medical and scientific devices.
The partnership between Solar Manufacturing and MSL began in 2016, and this new Mentor® Pro vacuum furnace (HFL-3036-2IQ) will be manufactured in accordance with CE standards including the vacuum chamber being built to ASME/UKCA requirements.
This furnace has a working hot zone area of 18” wide x 18” high x 36” deep (457mm x 457mm x 914mm) with a weight capacity of 1,000 pounds (455 kgs). It will be able to reach temperatures up to 2400°F (1315°C) and will feature a three gas partial pressure system and an internal quench system designed for 2-bar (15 PSIG) positive pressure quenching.
"MSL Heat Treatment specialize in brazing and controlled heat treatment for medical and scientific applications," Colin Woolger, director of MSL Heat Treatment added, "This latest furnace [. . .] will enable us to continue to provide high quality solutions to our growing customer base. The inclusion of hydrogen as a process gas also allows us to utilize the furnace for magnetic annealing to a very high specification."
"[We're] pleased to continue working with MSL as a supplier for their thermal processing needs," stated Rick Jones, vice president of International Sales at Solar Manufacturing. This will be the third vacuum furnace that the heat treat furnace provider will supply to MSL Heat Treatment.
Vacuum Heat Treat Capabilities Expand for Magnetic Shields Ltd Read More »
Time To Evacuate Atmospheric Pressure
Source: Ipsen Harold
Time to evacuate! When it comes to evacuating atmospheric pressure from vacuum furnace chambers, the addition of a diffusion pump can help attain a lower system pressure than the typical roughing pump and vacuum booster pump allow.
This best of the web article identifies the basics of vacuum furnace pumps and then explains how diffusion pumps in particular work and identifies a few considerations to think about to determine if you need this addition or not.
"For the diffusion pump to function properly, the main and foreline valves must be open, allowing the furnace to operate in high vacuum. Fluid at the bottom of the pump is heated to boiling and forced up through the center of the jet assembly."
Read more at "Ask the Expert: How Does a Diffusion Pump Really Work?"
Time To Evacuate Atmospheric Pressure Read More »
The Chemistry Behind the Process: 6 Heat Treat Tips for Brazing, Induction, and Quenching
OCWe’ve assembled some of the top 101 Heat Treat Tips that heat treating professionals submitted over the last three years into today’s original content. If you want more, search for “101 heat treat tips” on the website! Today’s tips will remind you of the importance of materials science and chemistry.
By the way, Heat Treat Today introduced Heat Treat Resources last year; this is a feature you can use when you’re at the plant or on the road. Check out the digital edition of the September Tradeshow magazine to check it out yourself!
Induction Hardening Cast Iron
(Dr. Valery Rudnev, FASM, Fellow IFHTSE, Professor Induction, Director Science & Technology, Inductoheat Inc.)
14 Quench Oil Selection Tips
  1. Part Material – chemistry & hardenability
  2. Part loading – fixturing, girds, baskets, part spacing, etc.
  3. Part geometry and mass – thin parts, thick parts, large changes in section size
  4. Distortion characteristics of the part (as a function of loading)
  5. Stress state from prior (manufacturing) operations
  6. Oil type – characteristics, cooling curve data
  7. Oil speed – fast, medium, slow, or marquench
  8. Oil temperature and maximum rate of rise
  9. Agitation – agitators (fixed or variable speed) or pumps
  10. Effective quench tank volume
  11. Quench tank design factors, including number of agitators or pumps, location of agitators, size of agitators, propellor size (diameter, clearance in draft tube), internal tank baffling (draft tubes, directional flow vanes, etc.), flow direction, quench elevator design (flow restrictions), volume of oil, type of agitator (fixed v. 2 speed v. variable speed), maximum (design) temperature rise, and heat exchanger type, size, heat removal rate in BTU/hr & instantaneous BTU/minute.
  12. Height of oil over the load
  13. Required flow velocity through the workload
  14. Post heat treat operations (if any)
(Dan Herring, “The Heat Treat Doctor®”, of The HERRING GROUP, Inc.)
How to Achieve a Good Braze
In vacuum brazing, be certain the faying surfaces are clean, close and parallel. This ensures the capillary action needed for a good braze.
A good brazing filler metal should:
  1. Be able to wet and make a strong bond on the base metal on which it’s to be applied.
  2. Have suitable melt and flow capabilities to permit the necessary capillary action.
  3. Have a well-blended stable chemistry, with minimal separation in the liquid state.
  4. Produce a good braze joint to meet the strength and corrosion requirements.
  5. Depending on the requirements, be able to produce or avoid base metal filler metal interactions.
(ECM USA)
(Dan Herring, The Heat Treat Doctor®)
Determine your quench: Induction or Immersion? Different aqueous quenchants will provide either faster or slower cooling depending upon induction or immersion quenching applications. It is important to select the proper quenchant to meet required metallurgical properties for the application.
  1. Part material: Chemistry and hardenability are important for the critical cooling rate for the application.
  2. Part material: Minimum and maximum section thickness is required to select the proper aqueous quenchant and concentration.
  3. Select the correct aqueous quenchant for the application as there are different chemistries. Choosing the correct aqueous quenchant will provide the required metallurgical properties.
  4. Review selected aqueous quenchant for physical characteristics and cooling curve data at respective concentrations.
  5. Filtration is important for aqueous quenchants to keep the solution as clean as possible.
  6. Check concentration of aqueous quenchant via kinematic viscosity, refractometer, or Greenlight Unit. Concentration should be monitored on a regular basis to ensure the quenchant’s heat extraction capabilities.
  7. Check for contamination (hydraulic oil, etc.) which can have an adverse effect on the products cooling curves and possibly affect metallurgical properties.
  8. Check pH to ensure proper corrosion protection on parts and equipment.
  9. Check microbiologicals which can foul the aqueous quenchant causing unpleasant odors in the quench tank and working environment. If necessary utilize a biostable aqueous quenchant.
  10. Implement a proactive maintenance program from your supplier.
(Quaker Houghton)
Container Clarity Counts!
(Rick Kaletsky)
The Chemistry Behind the Process: 6 Heat Treat Tips for Brazing, Induction, and Quenching Read More »
International Cutting Tool Manufacturer Increases Capabilities with Vacuum Tempering Furnace
Piotr Zawistowski
Managing Director
SECO/VACUUM TECHNOLOGIES, USA
Source: secowarwick.com
HTD Size-PR LogoAn international manufacturer of cutting tools purchased a vacuum tempering furnace. This North American-made, horizontal, front-loading furnace is purpose-built to accommodate the client's needs with an all-metal hot zone for clean vacuum processing. As with the earlier furnaces from the same supplier, one of which was installed at a different facility, the new furnace includes a convection fan and a pressurized gas quench for quick cooling.
This is the fourth Vector furnace solution provided to the client. "There is no stronger statement," states Piotr Zawistowski, president of SECO/VACUUM, "[. . . ] than the customer who continues to order more of the same technology from us year after year as they expand. We are privileged to be a part of their growth."
Maciej Korecki
Vice President of the Vacuum Furnace Segment
SECO/WARWICK
(source: SECO/WARWICK)
"This customer demands – and has come to expect from us – a complete range of benefits, including precision heat treat uniformity, consistency from one workload to the next, and fast processing speeds along with low energy consumption," noted Maciej Korecki, vice president of the Vacuum Furnace Segment at SECO/WARWICK Group.
This single-chamber vacuum heat treating furnace is a good solution for machine tool manufacturers and is available with curved graphite elements or an all-metal hot zone. Additionally, it can be used for most standard hardening, tempering, annealing, solution heat treating, brazing and sintering applications.
International Cutting Tool Manufacturer Increases Capabilities with Vacuum Tempering Furnace Read More »
Heat Treater Expands Controlled Atmosphere Brazing Capabilities
HTD Size-PR LogoAn industrial heat exchanger manufacturer based in the UK will receive a new controlled atmosphere aluminum brazing line. This system will allow the manufacturer to expand its range of sizes and dimensions of aluminum heat exchangers that can be brazed using the CAB technology.
The supplier of the system, North American manufacturer SECO/VACUUM parent company SECO/WARWICK, shared that the Active Only line offers the greatest flexibility within the CAB furnace range while maintaining the same performance as larger continuous lines. These capabilities were important in order to accommodate the manufacturer's wide ranging portfolio, which includes heat exchangers for various industries.
Piotr Skarbiński
Vice President of the Aluminum Process and CAB Business Segments
SECO/WARWICK Group
Source: SECO/WARWICK
The line will consist of a degreaser with afterburner and integrated energy recovery system, a spray fluxer, and an Active Only semi-continuous furnace. The system is composed of a dryer, a purging chamber, a convection-heated brazing furnace, a protective atmosphere cooling chamber, and a final cooling chamber. This will be complemented by an integrated system for loading, sequencing, stacking, transferring, and unloading the work in progress.
"We delivered our first furnace to this company 17 years ago, in 2004," says Piotr Skarbiński, Vice President of the Aluminum & CAB Products Segment at the SECO/WARWICK Group. "It was a furnace designed for the cutting-edge copper brazing technology of that time."
Heat Treater Expands Controlled Atmosphere Brazing Capabilities Read More »
International Military Equipment Heat Treaters Receive Vacuum Furnace
Maciej Korecki
SECO/WARWICK
AHTD Size-PR Logon international arms and military equipment manufacturer in Brazil needed to quickly expand and was recently able to receive a new vacuum furnace to meet their manufacturing demands.
The solution was provided by the parent company to North American SECO/VACUUM, SECO/WARWICK. Their furnace, the VECTOR®, is a single-chamber vacuum furnace that uses gas quenching and can be used for multiple metal heat treatment applications and processes. In this configuration, equipped with a round graphite heating chamber, it may be used for most standard processes including hardening, tempering, annealing, solutionizing, brazing and sintering.
"A situation where we have a product almost ready to be collected is rare. This time, the customer was indeed looking for a standard solution," said Maciej Korecki, vice president of the Vacuum Furnace Segment at the SECO/WARWICK Group.
(source: vidar nordli mathisen at Unsplash.com)
International Military Equipment Heat Treaters Receive Vacuum Furnace Read More »
