box furnace
Heat Treat Box Furnace Shipped to Manufacturer
Bill St. Thomas
Business Development Manager
Lindberg/MPH
Source: Lindberg/MPH.com
A rod overbend box furnace with powered load/unload table is being shipped from Michigan to a manufacturer. An automated actuator increases safety measures protecting the operator.
Lindberg/MPH's furnace has a maximum temperature rating of 2,000°F and a load capacity of 900 lbs. The workspace dimensions of the furnace are 24” x 36” x 18” and is designed for air atmosphere applications. The box furnace features an automated actuator to flip the push/pull mechanism on the load table to eliminate the operators need to manually flip it into push position. This option allows the push/pull head to retract from the furnace once the work grid is in the furnace chamber and increases operator safety by removing the need to reach into the hot furnace with a hook to flip the push/pull head.
“This furnace design is a duplicate to a previous order . . . . with the [requested] modification of an automated actuator to provide easier loading for the operator," commented Bill St. Thomas, business development manager at Lindberg/MPH.
Heat Treat Box Furnace Shipped to Manufacturer Read More »
Heat Treat Radio #97: Lunch & Learn, Ovens vs. Atmosphere Furnaces
Are you trying to figure out what heat treat equipment investments you need to make in-house and what is better being outsourced? This conversation marks the continuation of Lunch & Learn, a Heat Treat Radio podcast series where an expert in the industry breaks down a heat treat fundamental with Doug Glenn, publisher of Heat Treat Today and host of the podcast, and the Heat Treat Today team. This conversation with Dan Herring, The Heat Treat Doctor®, zeros in on heat treat ovens versus atmosphere furnaces.
All About Ovens (01:42)
Universal oven from Grieve
Source: Grieve
"Metal lined oven"
Source: Dan Herring
"Double door shelf oven"
Source: Dan Herring
"A larger horizontal oven . . . . a fan system sitting at back"
Source: Dan Herring
"Walk in oven"
Source: Dan Herring
"Industrial oven . . . . typical oven in typical heat treat shop"
Source: Dan Herring
"Monorail conveyor oven . . . . with u-shaped radiant tubes"
Source: Dan Herring
Q&A on Ovens (16:58)
Heat Treat Today team enjoying a Lunch & Learn session
A 14-foot long car bottom furnace
"A box furnace . . . . sometimes difficult by sight alone to tell an oven or box furnace"
Source: Dan Herring
"A box furnace with retort"
Source: Dan Herring
"A pit style furnace . . . . there is probably 4X as much furnace below the floor"
Source: Dan Herring
"An integral quench furnace, an in-out furnace"
Source: Dan Herring
"A humpback style furnace"
Source: Dan Herring
Dan Herring: Well thank you, my pleasure.
For more information:
www.heat-treat-doctor
dherring@heat-treat-doctor.com
Heat Treat Radio #97: Lunch & Learn, Ovens vs. Atmosphere Furnaces Read More »
Heat Treat Bench-Top Box Furnace Delivered to Equipment Distributor
A highly uniform box furnace was sent to a distributor of equipment to maintenance repair and overhaul (MRO) facilities located throughout the world. The furnace manufacturer is based in Pennsylvania and supplies this equipment for lab samples and general manufacturing.
The L&L Special Furnace Model XLB124 has working dimensions of 11” wide by 10” high by 22” deep. The furnace is capable of heat treating and tempering. It is equipped with a sealed case for inert atmosphere capability, as well as a fully functional atmosphere control panel with pressure regulator, flowmeter and manual shut-off valve. Two-zone, long-lasting solid-state contactors control the power, and the furnace hearth is a rugged cordierite plate with ceramic support.
Heat Treat Bench-Top Box Furnace Delivered to Equipment Distributor Read More »
Heat Treat Furnace Received for Annealing RF/Microwave Components
HTD Size-PR LogoA US manufacturer of radio frequency (RF) and microwave components recently received a small box furnace reaching 2300°F. This furnace will be used for precision heating to anneal their parts before milling.
The small load custom box furnace was delivered by Lucifer Furnaces. It is their furnace model HL7-A12 with a 6” x 6” x 12” chamber and is insulated with a combined 5” hot face insulating firebrick and cold face mineral wool backup. This box furnace is complete with a cast hearth plate to protect the floor insulation and heats with easy-to-replace coiled heating elements in cast assemblies for easy replacement, while still being built at the same quality as larger models.
Controls include a Honeywell digital time proportioning temperature controller and a TP1 Soak Timer which starts when the furnace reaches setpoint temperature and shuts off the elements at the end of the heating cycle. A door safety switch automatically disengages power to the elements when the door is opened. This furnace is part of Lucifer’s standard, general purpose, series 7000 box furnace line, a line which helps bring clients’ heat treating in-house and gain control over work flow and product quality.
Heat Treat Furnace Received for Annealing RF/Microwave Components Read More »
Heat Treating Capabilities for Medical Expand at Optical Laboratory
HTD Size-PR LogoAn optical laboratory in northeastern USA will receive a second floor-standing box furnace for heat-treating ceramics and optics used in the medical field.
The L&L Special Furnace Company model XLE 3636 has an effective work zone of 34” wide by 30” high by 32” deep. It features a double pivot horizontal door. The ceramic hearth is supported on lightweight castable piers. A series of heat shields are included to ensure a safe case temperature while at operating temperatures. The furnace is designed for use with inert blanketing gas for atmosphere control to minimize oxidization. A manual flow panel with regulator and flow meter is included.
A Eurotherm program control and high limit safety are standard. The furnace has a stack light mounted to the top of the control panel for an audible and visual indication of current furnace status. Solid-state relays drive the furnace, which is NFPA86 compliant. Startup and training packages are also included to help the customer set up the furnace and process.
Heat Treating Capabilities for Medical Expand at Optical Laboratory Read More »
