aluminum processing
Aluminum Processing Growth
FIgure 1. Critical temperature phase transitions of the T6 aluminum heat treatment process
Source: PhoenixTM
Figure 2. Thru-process temperature monitoring of the three T6 heat treatment phases
Source: PhoenixTM
Figure 3. Thru-process temperature profiling system installed in the product cage monitoring the T6 heat treatment (solution treatment, quench, and age hardening) of aluminum engine blocks
Thermal Protection Technology
Figure 4. TS06 thermal barrier design showing water tank, housing the data logger at its core, installed within structural frame containing the insulation blanket surface layer; water tank shown with traditional compression fitting face plate seal
Source: PhoenixTM
Figure 5. TS06 thermal barrier IP67 bi-directional rubber gasket seal; installation of mineral-insulated (MI) thermocouples and RF antenna aerial
Figure 6. View of TUS for T6 aluminum processing in Phase 1 Solution Re-heat
Source: PhoenixTM
Summary
Dr Steve Offley (“Dr O”), Product Marketing Manager, PhoenixTM
For more information: Contact Steve at Steve.Offley@phoenixtm.com.
Heat Treat Furnace to Expand Capabilities of Plumbing Tube Manufacturer
Keith Boeckenhauer
Managing Director
SECO/WARWICK USA
A Virginia manufacturer of high-quality plumbing tube recently commissioned a new heat treat furnace, expanding the plant’s capabilities to include aluminum extrusions. This is the first new aluminum processing equipment installation at the plant.
The supplier, SECO/WARWICK, noted that the vertical orientation of the work being heat treated is what differentiates this from others. The design allows the customer to maintain an efficient, semi-continuous process with little downtime between batches by staging loads in the drywells. The major benefit of this design is that it will allow the manufacturer to drop extrusions into the quench within 10 seconds after heat treating and soak.
Keith Boeckenhauer, managing director of SECO/WARWICK USA, commented that the company "has patented many standard processes related to aluminum heat treatment and controlled atmosphere brazing, [and is able. . .] to apply innovative designs to custom requirements."
The furnace was designed and built in Pennsylvania.
(photo source: Jacek Dylag at unsplash.com)
All other images sourced from secowarwick.com.
Heat Treat Furnace to Expand Capabilities of Plumbing Tube Manufacturer Read More »
